    Home»Atto Super Air Nozzle For Precise Blowoff
    VincentBy VincentSeptember 21, 2011Updated:June 2, 2013No Comments1 Min Read
    EXAIR’s new Atto Super Air Nozzle™ has been engineered to produce the highest performance attainable from a tiny nozzle. It delivers the smallest, most precise blowoff with an efficient, high volume, high velocity airflow. The overall length of the air nozzle measures only 0.50″ (12.7mm) with a diameter of only 0.16″ (4mm), permitting installation in tight spaces. The durable Type 316 stainless steel construction is suitable for blowoff, cooling and drying applications located in general industrial, high temperature, food, pharmaceutical, semiconductor or corrosive environments.
    The Model 1108SS Atto Super Air Nozzle provides a narrowly focused air pattern. High amplification of airflow and a strong blowing force of 2.0 ounces (56.7 grams) are achieved with minimal air consumption of 2.5 SCFM at 80 PSIG. Safe operation is assured since the airflow of the Atto Super Air Nozzle cannot be blocked, which meets the OSHA standard for dead-end pressure 29 CFR 1910.242(b). Sound level is very low at 58 dBA and meets OSHA noise requirement
    29 CFR 1910.95(a), as well as being CE compliant.
    The Atto Super Air Nozzle is designed to easily replace existing wasteful nozzles or open pipes. The compressed air inlet is male M4 X 0.5. Price is $36.
