    Home » BIG KAISER releases two new chip breaker inserts for finish boring
    Noah GraffBy Noah GraffMay 8, 2020No Comments2 Mins Read
    Hoffman Estates, IL –  BIG KAISER Precision Tooling has released two new insert chip-breaker types designed to improve surface finish in long-chipping materials. Long chips that are difficult to evacuate can lead to poor surface finishes when chips are dragged around by the tool. Insert life can be severely reduced if these chips are re-cut by the insert, and in small-diameter applications stringy chips can wrap around the tool to the point where a crash occurs.
    The exclusive FLM 3D chip-breaker design is used on PCD-tipped inserts ideal for finishing of aluminum components, where traditional flat-top inserts may produce a large continuous nest of chips that is difficult to remove from the bore and/or tool, even with high-pressure coolant. Three different radius options are available: .008”, .016” and .031” for the insert TCGT2 (1.5).
    For finishing in mild- or construction steels, cermet inserts with chip-breaker form ELM should be used. Available in .008” radius and combined with a light depth of cut, this chip-breaker creates a high-shear angle to shorten the cutting chips for better evacuation and gives superior surface finishes in these traditionally difficult materials.
    Learn more about these and other boring inserts from BIG KAISER here,  including several pressed and ground-geometry designs for optimum performance and tool life.
    BIG KAISER is a worldwide leader in high-precision tooling systems and solutions for the metalcutting industry that guarantee extreme accuracy and repeatability. Our products are of the utmost quality — manufactured with materials and craftsmanship that enable superior performance. As a member of the BIG DAISHOWA Group (Osaka, Japan), BIG KAISER has grown into a well-recognized global tooling provider, with manufacturing facilities in North America, Switzerland and Japan. In addition, BIG KAISER is the North American representative of Speroni tool measuring machines, Sphinx high performance drills, mptec measuring stands, Tekusa spindle cleaners and the UNILOCK zero point workholding system by Innotool.
    For more information, contact BIG KAISER, Hoffman Estates, IL at 224-770-2999, e-mail bigkaiser@us.bigkaiser.com or visit www.us.bigkaiser.com.
