    Home » EXAIR’s new 1/4 NPT internal mix deflected flat fan atomizing spray nozzle
    Emily HalgrimsonBy Emily HalgrimsonDecember 16, 2015No Comments2 Mins Read
    NEW PRODUCT: Spray Nozzle Coats, Cools, Treats and Paints in Tight Spaces
    EXAIR’s 1/4 NPT internal mix deflected flat fan atomizing spray nozzle atomizes fluid and sprays at a right angle to the nozzle orientation. This allows spray to be placed precisely where it is needed when the mounting and work areas are limited. These nozzles are ideal for coating the inside of enclosures and ductwork. They combine liquid and compressed air inside of the air cap to produce the finest mist of atomized liquid that can be easily adjusted to meet the needs of your application. These spray nozzles provide liquid flows from 1.8 to 6.9 gallons per hour.
    With EXAIR’s atomizing nozzles, you can coat, cool, treat and paint a variety of products using compressed air and liquids with a viscosity of up to 300 centipoise. They are commonly used with water, light oils, rust inhibitors, chemicals, paints and dyes.
    The stainless steel construction of these atomizing nozzles adds to their durability and corrosion resistance. EXAIR atomizing nozzles are available with 1/4 NPT and 1/2 NPT connections and in a variety of sizes and shapes to meet your needs. All models are adjustable, come with our 5 year Built to Last Warranty and are CE compliant. Internal mix deflected flat fan spray nozzles start at $187.
    For more information contact:     EXAIR Corporation
    11510 Goldcoast Dr.
    Cincinnati, OH  45249-1621
    Phone: (800) 903-9247
    Fax: (513) 671-3363
    E-mail: techelp@exair.com
    www.exair.com/smad.htm
