    Home»EXAIR’s New Threaded Line Vac Makes it Easy to Convert Standard Pipe Into a Powerful, High Volume Conveyor
    Emily HalgrimsonBy Emily HalgrimsonAugust 19, 2017Updated:August 28, 2017No Comments2 Mins Read
    EXAIRs new aluminum 2-1/2 NPT and 3 NPT Threaded Line Vac Air Operated Conveyors convert ordinary pipe into a powerful conveying system for parts, scrap, trim and other bulk materials. Their larger size makes them perfect for conveying bigger parts and large volumes of material over long distances. The Threaded Line Vac is designed to attach to standard plumbing pipe couplers, making it easy to build a complete system using pipe and fittings available from any home center, hardware store or plumbers supply.
    Threaded Line Vac Conveyors eject a small amount of compressed air to produce a vacuum on one end with high output flows on the other. Response is instantaneous and regulating the compressed air pressure provides infinite control of the conveying rate. Applications include scrap trim removal, material conveying, part transfer, fiber tensioning and filling operations.
    Aluminum Threaded Line Vacs are CE compliant and meet OSHA pressure requirements. Smaller sizes down to 3/8 NPT are available in stock. Threaded Line Vac models are also available in type 303 and type 316 stainless steel for more demanding high temperature, corrosive and hygienic environments. Line Vacs also come with smooth ends for use with hose and tubing and Heavy Duty Line Vacs provide abrasion resistance while producing maximum power for high bulk density material. If a secure pipe connection is required where the Line Vac will be frequently removed for cleaning, Sanitary Flange Line Vacs are also available. Aluminum Threaded Line Vac prices start at $110.00.
    For more information contact:
    EXAIR Corporation
    11510 Goldcoast Dr.
    Cincinnati, OH  45249-1621
    Phone: (800) 903-9247
    Fax: (513) 671-3363
    E-mail: techelp@exair.com
