    Home»FlexiSan Modular Spray System for Mobile and Efficient Equipment and Plant Sanitation
    AdminBy AdminFebruary 26, 2026No Comments2 Mins Read
    Portable open plant cleaning cart, Clean-in-Place spray headers, optional pump package, and other add-ons. overlayed on a BETE White and soft BETE Greenn Blue "inset" with a pipe with 3 BETE nozzles Developing a spray pattern.
    BETE’s FlexiSan™ Modular Spraying System offers a portable, cost-effective spray solution that enables mobility and effective cleaning and sanitization across a wide range of industrial applications. Engineered for flexibility and performance, the FlexiSan system allows operators to quickly rinse and apply cleaning and sanitizing agents to a variety of equipment, including conveyors, hoppers, bins, and mixers, as well as other critical process areas.
    The FlexiSan is designed to handle everything from light washdowns to heavy cleanups of thicker, more stubborn build-ups. The base model offers a mobile cart with a Clean-in-Place spray header that connects directly to a facility’s water line. With two separate blending pumps, the spray system can hold up to two liquids simultaneously, enabling seamless switching between rinsing, cleaning, and sanitizing. For heavier soil levels, BETE also offers a FlexiSan Max Spraying System, providing additional power. Its precision spraying minimizes waste for the chosen liquid and provides a mobile solution for use throughout a plant.
    The FlexiSan system is part of BETE’s comprehensive portfolio of spray technology designed to optimize performance and efficiency. In addition to modular spraying systems, BETE offers fine spray, air atomizing, tank washing, spiral, full and hollow cone, and flat fan nozzles to support virtually any industrial spray application. With decades of spray engineering expertise, BETE continues to deliver reliable, high-performance solutions tailored to the most demanding environments. https://exair.co/flex
