    Home»Kingfisher Boats use JETCAM to fully automate CNC router NC code generation
    AdminBy AdminMay 21, 2025Updated:May 21, 2025No Comments4 Mins Read
    Kingfisher Boats, based in Vernon, BC, Canada, has manufactured a range of welded aluminium hull boats since 1959. Due to the fluctuating cost of aluminium, the company researched the market for better software, eventually purchasing JETCAM Expert CADCAM with High Performance Nesting and a single postprocessor to drive an ESAB plasma cutter in 2008. A Multicam router post was added in 2015, and a second in 2017, with the ESAB being retired in 2024.
    Kingfisher Boats had already been using the software for 16 years when Bob Hackl, Product Development Technologist, took over the management of the software in January 2024, after previously operating the CNC routers. Despite very little experience with CADCAM or nesting software he was able to get up and running very quickly, commenting; “I found it very easy to learn the basics of JETCAM.” When performing CAD Import, JETCAM’s Single Component Automatic Processing (SCAP) was able to provide a fast and automated process of importing DWGs and applying automatic tooling for both routers. Bob noted; “I just enter the source and destination locations, plus part thickness and click Go.” Entire directories can then be processed without further user input. JETCAM Expert stores tooling at the component level on a per-machine basis, meaning that parts can be tooled for multiple machines automatically, and are then instantly  available for nesting and NC code generation on any machine.
    Automatic Tooling takes care of all routing without any required user input during CAD import. Multi-depth routing, scribing, partial depth cutting and corner pocketing are all configured once and then applied automatically with auto-tooling.
    With the instability of raw material prices and global price wars, prices fluctuated between $1600 and over $4000 per metric ton between 2020 and 2022. Kingfisher Boats has been able to take advantage of High Performance Nesting’s time-based approach to nesting. This allows Bob to choose whether to let the nester try for the best efficiency, or opt for speed. He said; “HPN is set to run for 5 minutes by default, but I’ll often stop it under 3 minutes, as nests are usually very efficient by then.”
    The company also benefits from the flexibility of being able to perform static or dynamic nesting. As many parts are repeated, static nests that have been optimally produced using HPN offer good material efficiency. However, being able to create a nest that either has a mix of orders or perhaps including parts scrapped further on in production gives Kingfisher complete flexibility. Noted Bob; “We generally static nest, but if we have to deal with significant changes then it’s no issue to create a new nest dynamically.”
    When Bob transitioned from CNC operator to programmer, he had little experience of nesting. However, in addition to the system being easy to learn, Bob also took advantage of JETCAM’s online University, which includes hundreds of free to access tutorial videos. Having viewed over 90 videos, he noted; “I found the JETCAM University extremely informative.”Local support by their local reseller, NestOne Solutions, has also been excellent, with all questions answered quickly, positively and fully. “NestOne have always been very helpful, with all questions answered quickly and satisfactorily.”
    With over 75 years of manufacturing expertise behind them, Kingfisher is confident that JETCAM is the right partner to take them forward. Bob finalized; “JETCAM is easy to learn, especially using the University. It’s a powerful program with solid support. I’ve never had a problem that they couldn’t help me with.”
    Highlights
    • Have driven different technologies with the same software
    • Single Component Automatic Processing (SCAP) automates part creation and tooling
    • Can perform routing to different depths
    • High Performance Nesting delivers optimized nests in minutes
    • Able to perform both static and dynamic nesting
    • JETCAM University provides 24/7 help
    • Excellent local support from NestOne
