    Home»Lincoln Electric Introduces Fab-Pak® OmniClean™ Complete Robotic Grinding Cell
    AdminBy AdminMay 4, 2021Updated:July 19, 2022No Comments2 Mins Read
    Cleveland, OH (May 3, 2021) – The new Fab-Pak OmniClean all-in-one robotic grinding cell from Lincoln Electric and 3M simplifies pre- and post-weld grinding for small- and medium-size parts without the added time and expense of building and installing a custom cell.
    Ideal for general metal fabrication in low-mix, high-volume job-shop industries, this turnkey system is backed by Lincoln Electric Automation’s robotic integration expertise and 3M’s world-class abrasives and application engineering support.
    The Fab-Pak OmniClean grinding cell, available with a 3HP or 5HP 3M™ Active Compliant Tool, comes packaged with everything needed to deliver consistent weld removal by grinding parts robotically. The single station Headstock/Tailstock system includes a FANUC® robot equipped with a 3M Servo Rotary Tool that ensures consistent speed at varying force loads and built-in, tool-changing functionality.
    The 3M Active Compliant Tool applies the right amount of force for optimal grinding performance for specific applications and required finishes. Both of these features are designed to optimize performance of included 3M abrasives for productivity and part consistency. Each cell comes with an abrasives starter pack with the choice of 3M Cubitron™ II Fibre or Scotch-Brite™ Surface Conditioning discs. Both are designed to quickly remove and clean welds.
    The Fab-Pak OmniClean grinding cell requires minimal assembly, installation and setup, thanks to its single system base design. The cell also features a fully integrated software package to adjust parameters and maintain safety features of the active compliance device.
    For more information on the Fab-Pak OmniClean robotic grinding cell, visit www.lincolnelectric.com/fab-pak-omniclean
    About Lincoln Electric
    Lincoln Electric is the world leader in the design, development and manufacture of arc welding products, automated joining, assembly and cutting systems, plasma and oxy-fuel cutting equipment and has a leading global position in brazing and soldering alloys. Headquartered in Cleveland, Ohio, Lincoln has 59 manufacturing locations in 18 countries and a worldwide network of distributors and sales offices covering more than 160 countries. For more information about Lincoln Electric and its products and services, visit the Company’s website at https://www.lincolnelectric.com.
