    Home » New Powerful Stainless Steel Flat Air Nozzle Saves Space, Saves Money and Resists Corrosion
    Emily HalgrimsonBy Emily HalgrimsonOctober 9, 2013Updated:October 10, 2013No Comments2 Mins Read
    EXAIR’s new 1″ Stainless Steel Flat Super Air Nozzle™ produces a flat 1″ (25mm) wide airstream with a strong blowing force of 9.8 ounces (278g) when mounted 12″ (305mm) from the target. The unique design of this super-efficient nozzle makes it an ideal fit for both tight spaces and tight budgets, plus the Type 316 stainless steel construction makes it ideal for corrosive, high temperature, food and pharmaceutical environments.
    The 1″ Flat Super Air Nozzle uses EXAIR’s patented technology to maximize entrained airflow while reducing noise levels. A precise amount of air is released through the .015″ (0.38mm) air gap opening that is set with a stainless steel shim positioned between the body and removable cap. The high velocity airstream pulls in surrounding room air to produce a wide, forceful stream of laminar airflow. Air consumption is 10.5 SCFM at 80 PSIG. Force and flow may be easily adjusted by installing different shim thicknesses.
    The 1″ Flat Super Air Nozzle is also available in zinc aluminum alloy construction, suitable for rugged industrial applications. Applications include ejecting heavy parts and slugs, chip removal, part cleaning, drying, liquid blowoff and cooling. Price is $79.
    For more information contact:
    EXAIR Corporation
    11510 Goldcoast Dr.
    Cincinnati, OH  45249-1621
    Phone: (800) 903-9247
    Fax: (513) 671-3363
    E-mail: techelp@exair.com
    www.exair.com/1sanss.htm
