    Home»NEW PRODUCT BY EXAIR: Back Blow Air Nozzle For Cleaning Inside Diameters
    Emily HalgrimsonBy Emily HalgrimsonJune 5, 2015Updated:June 17, 2015No Comments2 Mins Read
    EXAIR’s new 1/4 NPT Back Blow Air Nozzle has been designed to effectively blow debris and liquids from pipe or hose inside diameters, channel, bores, holes, internal threads and other internal part features. An array of holes provide a forceful 360 degree airflow to clear out coolant, chips and light oils from machining processes. This nozzle prevents blowing chips further into a part, tube or pipe and eliminates any safety hazard created by blowing debris out the far end of a pipe or tube.
    The Model 1006SS Back Blow Air Nozzle is manufactured with a small profile and will fit inside openings as small as 7/8″ and is effective on diameters up to 4″. It is constructed of type 316 stainless steel to provide durability and superior resistance to corrosion. Installation is simplified and a secure fit is assured with 5/8″ flats milled on the body. Since airflow is directed back toward the operator, personal protective equipment is recommended. Chip shields to protect the operator from the exiting debris are available. Extension pipes from 12″ to 72″ are stocked to provide necessary reach for longer tube and pipe clean out.
    Sound level is low at 80 dBA and meets OSHA noise requirement 29 CFR 1910.95(a), as well as being CE compliant. Price is $92.
    For more information, contact: EXAIR Corporation
    11510 Goldcoast Dr.
    Cincinnati, OH 45249-1621
    Phone: (800) 903-9247
    Fax: (513) 671-3363
    E-mail: techelp@exair.com
    www.exair.com/back.htm
