    Home»NEW PRODUCT: New No Drip External Mix Atomizing Nozzles Positively Stop Liquid Flow
    Emily HalgrimsonBy Emily HalgrimsonSeptember 30, 2015No Comments2 Mins Read
    External Mix Atomizing Spray Nozzles mix liquid and air outside the nozzle and allow the air and liquid flows to be adjusted independently. The new, patent pending, No Drip External Mix Atomizing Spray Nozzles work in the same way our standard atomizing nozzles do, but have the added benefit of positively stopping liquid flow when compressed air is shut off.
    When spraying any type of liquid, post-spray liquid flow can cause big problems. Unwanted drips can ruin product function on sealing or mating surfaces. Drips can also ruin the appearance of painted or coated finishes. In addition, excess liquid flow wastes precious resources such as expensive coatings, chemicals or water. EXAIR’s No Drip Atomizing Nozzles are ideal where no post-spray drip is permissible. When the compressed air supply is shut off, the no drip nozzle positively seals off the flow of liquid eliminating the possibility of drips.
    EXAIR’s No Drip External Mix Atomizing Nozzles are available in three different liquid patterns: round, narrow angle flat fan and wide angle flat fan patterns. They are for pressure fed applications where precise liquid flow is needed. External nozzles can be used on liquids up to 800 centipoise.
    Applications include painting, coating, rinsing, cooling, quenching, wetting (moistening), dust control and humidification. The compact Atomizing Nozzles are fully adjustable to minimize air and liquid consumption and have interchangeable liquid and air caps. They are CE compliant and conflict mineral free. Prices start at $346.
    For more information contact:
    EXAIR Corporation
    11510 Goldcoast Dr.
    Cincinnati, OH  45249-1621
    Phone: (800) 903-9247
    Fax: (513) 671-3363
    E-mail: techelp@exair.com
    www.exair.com/ndextmix.htm
