    Home»Okuma’s ServoNavi CNC Machining Technology Improves Cycle Time for Heavy Parts
    Emily HalgrimsonBy Emily HalgrimsonMay 5, 2014No Comments2 Mins Read
    ServoNavi prevents inaccuracies by addressing three areas of the CNC machining process
    High-precision technology improves cycle times and accuracy for heavy parts
    CHARLOTTE, N.C. (March 17, 2014) – Okuma’s ServoNavi is a high-precision technology that improves cycle times and accuracy when machining heavy parts. This technology can be applied on all Okuma double column, vertical, and horizontal machining centers.
    ServoNavi uses the weight of the part/workholding to control servo control accuracy. In the past, the weight was set manually, but incorrect weight would cause machining inaccuracies. ServoNavi prevents inaccuracies by addressing three areas of the CNC machining process:
    • Work Weight Auto Setting: On previous machining centers, actual table feed acceleration varied with different table loads (workpiece, fixture). ServoNavi’s Work Weight Auto Setting function automatically estimates table loads to adjust for the best acceleration speed – and achieve faster cycle times.
    • Reversal Spike Auto Adjustment: Machine tool utilization times and slide loads vary from the ideal servo control settings determined at initial machine delivery. This may produce crease marks at motion reversals and affect part surface quality. ServoNavi’s Reversal Spike Auto Adjustment compensates for slide load variations, and with optimized servo control, maintains the required CNC machining accuracies (surface quality).
    • Vibration Auto Adjustment: Noise or vibration may occur when machine conditions change over time. ServoNavi’s Vibration Auto Adjustment makes the required adjustments for the changed conditions to effectively eliminate noise and vibration.
    To request additional information on ServoNavi CNC machining technology, contact Okuma America Corporation http://www.okuma.com/contact-us or your local Okuma distributor http://www.okuma.com/distributors.
    Okuma America Corporation is the U.S.-based sales and service affiliate of Okuma Corporation, a world leader in CNC (computer numeric control) machine tools, founded in 1898 in Nagoya, Japan. The company is the industry’s only single-source provider, with the CNC machine, drive, motors, encoders, spindle and CNC control all manufactured by Okuma. Okuma’s innovative and reliable technology, paired with comprehensive, localized service protection, allows users to run continuously with confidence – maximizing profitability.  Along with its industry-leading distribution network (largest in the Americas), and Partners in THINC, Okuma facilitates quality, productivity and efficiency, empowering the customer and enabling competitive advantage in today’s demanding manufacturing environment.  For more information, visit www.okuma.com/americas or follow us on Facebook or Twitter @OkumaAmerica.
