    Home » Rollomatic Achieves Nano-Range Surface Finish on Laser Machining PCBN Material
    AdminBy AdminJanuary 31, 2022Updated:July 19, 2022No Comments4 Mins Read
    Rollomatic Milestone Achievement of Nano-Range  Surface Finish on Laser Machining PCBN Material
    Rollomatic maintains its leadership position in the field of laser cutting ultra-hard materials by announcing  a breakthrough in achieving the highest possible surface finishing in machining PCBN material. Rollomatic  succeeded in producing a surface finish of Ra 48 nanometers (0.048 micrometer) on a primary relief of a  profile insert in PCBN material.
    The tests were performed on the LaserSmart® LS510 cutting and ablation machine with 5 interpolating  CNC axes. A “super-mirror” finish is generally known to be around 100 nanometers which Rollomatic was  able to cut in half.
    These tests were performed at the Rollomatic showroom facility in Mundelein, IL, USA, without sacrificing  on feedrates or cycle times. In particular, the process ensured that the integrity of the edge quality was  fully maintained without compromise.
    The verification and measuring process was carried out by a Bruker-Alicona EdgeMaster Optical 3- Dimensional Metrology Unit.
     Fanuc high-speed robot for Rollomatic ShapeSmart® LS510 Round-shaft PCD profile tools  automatic loading and unloading
    This machine produces the sharpest corner radius in the PCD/CBN industry with a maximum radius on the  cutting edge below 0.5 micron. In addition, a defined radius of 3, 6 and 9 microns can also be produced  consistently. In addition to round-shaft tools, HSK63 shanks can also be accommodated on this machine.
    The strategy for this machine is to offer a more cost-effective way and higher quality in the production  of high-performance PCD polycrystalline diamond, CBN cubic boron nitride and CVD chemical vapor  deposited cutting tools which traditionally require to be produced by a double process of spark erosion  and polish grinding.
    ∙ Up to 4 times faster feedrates with identical edge and surface quality.
    ∙ 3D machining of drill points and endmill cutting geometries.
    ∙ Process to sharpen the cutting edge of CVD or thick-film diamond coated cutting tools.  ∙ Fine-laser cutting achieves a superfine cutting edge with a surface finish that is unachievable by  grinding/EDM.
    ∙ Conventional grinding with diamond wheels will invariably “pull out” an entire PCD crystals, while  laser cutting will “slice” through the crystal and leave a portion of the crystal in the matrix, thus  providing a razor-sharp cutting edge, unattainable by EDM, EDG (electro-discharge) or grinding.
    ∙ Linear motion technology on all linear and rotary axes provides highly accurate trajectories for  the complex cutting paths.
    ∙ Continuous field testing has shown that sharper cutting edges and superior surface quality on  PCD tools deliver longer tool life and higher feed rates during machining.
    ∙ Laser ablation allows the freedom to optimize tool geometries.
    ∙ Manufacturing chip form geometries in PCD is easily performed by this machine using the  ablation process as a cost-effective and powerful alternative to existing complicated and  expensive conventional methods.
    Rollomatic Inc., located in Mundelein, Illinois, is a subsidiary company of Rollomatic SA, a privately owned Swiss company established since 1989 in Le Landeron, Switzerland. The US Headquarter was  launched in 1994 to provide local customer service and support throughout the U.S., Mexico and  Canada.
    This location features at 29,000 sq. ft. building with a showroom and training area as well as warehouse  and engineering offices. Our showroom provides an ideal atmosphere for machine demos, software  training and test grinding, while offering an opportunity to explore the latest Rollomatic offerings.
    Rollomatic is looking to the future with its partners such as the EPFL (Swiss Technical University in research,  teaching and innovation) so it can be right at the center of the innovations and in-depth discussions  shaping the Fourth Industrial Revolution. True to its Swiss origins, the company operates at the highest  level of precision and offers 100% Swiss-built products and services. Rollomatic is in constant pursuit of  excellence in quality and accuracy.
