As shops look to automate, many quickly realize that buying a cobot or a spindle gripper is only half the battle. If your CNC workholding still requires a human hand to turn a handle, your CNC automation journey stops before it even begins. This realization has sparked a massive shift toward pneumatic vises—specifically self-centering vise models designed from the ground up for automated machine tending.
But not all pneumatic workholding is created equal. The market is currently split between expensive European imports, retrofitted manual machine vises, and a new generation of purpose-built CNC air vises that are changing the math for machine shops. One company in particular—California-based Gimbel Automation—has been gaining serious traction with a lineup that addresses the core pain points shops face when moving to automated workholding solutions.
The Problem with Traditional CNC Workholding in Automation
When a shop decides to automate a CNC mill, the first hurdle is always workholding. Traditional single-station vises, like the industry-standard Kurt vise, are incredibly rigid and reliable for manual operation. However, adapting them for CNC automation is notoriously difficult.
Some shops attempt to use pneumatic vise actuators to convert their existing manual cnc mill vises. While this can work, it often results in a bulky pneumatic vise clamp setup that eats up valuable table space and introduces new points of failure. Furthermore, standard single-station vises are not self-centering. When a machine tending robot or cobot loads a part, any variation in the raw stock size means the centerline of the part shifts, leading to scrapped parts and broken tools.
The alternative has traditionally been high-end European pneumatic clamping blocks, such as those from Schunk. These are exceptional pieces of engineering, but they come with a premium price tag—often exceeding $5,000 per workholding vise—and typically feature very small jaw strokes (often just 2mm per jaw). This limited stroke means operators must constantly swap vise jaws or make micro-adjustments when changing between different part sizes, defeating the flexibility that cobot machine tending is supposed to provide.
Gimbel Automation’s AutoVise™ Lineup: A New Standard in Pneumatic CNC Vises
Recognizing the gap between expensive imports and clunky retrofits, Gimbel Automation developed the AutoVise™ line of self-centering pneumatic CNC air vises. Designed specifically to eliminate hand-cranking and enable seamless CNC automation, the AutoVise™ solves the core problems shops face when implementing robotic or gripper-based machine tending.
The lineup currently includes three sizes, all available for purchase directly through the company’s Shopify store:
What Sets This Pneumatic Vise Apart from the Competition
The AutoVise™ delivers fast, repeatable, and fully automated clamping with the flip of a switch or an M-code command from the CNC control. But what truly sets this air vise apart in the crowded pneumatic workholding market are three critical design choices:
1 All-Steel Construction
Many entry-level pneumatic vises use aluminum bodies that flex under load. The AutoVise™ features an all-steel and stainless steel construction, engineered and supported for over 2,000,000 clamp cycles, with many units exceeding one million cycles without a rebuild.
2 No Soft Jaws Needed for Op 1
One of the biggest frustrations with traditional CNC workholding is the constant need to machine custom vise soft jaws. The AutoVise™ eliminates this for first-operation machining with fully serrated, adjustable hardened steel vise jaws that accommodate virtually any stock size in seconds.
3 Spring-Driven Failsafe
A unique spring-driven design provides 50% of total clamping force even if all air pressure is completely lost. Parts, tools, and machine remain safe regardless of pneumatic reliability—a critical feature for lights-out manufacturing environments.
Full Specifications Across the AutoVise™ Self-Centering Pneumatic Vise Line
All three sizes of the AutoVise™ self-centering pneumatic CNC vise share the same 0.0008″ repeatability and all-steel construction. Here is how they compare across the full spec sheet:
| Specification | 3″ (75mm) | 4″ (100mm) | 6″ (150mm) |
| Price | $2,679 | $2,789 | $4,379 |
| Jaw Width | 75mm / 3.0″ | 100mm / 4.0″ | 150mm / 6.0″ |
| Jaw Stroke | 5.0mm / 0.20″ | 5.0mm / 0.20″ | 10.0mm / 0.40″ |
| Inner Clamp Range | 8.5 – 47mm | 6.0 – 53mm | 10 – 107mm |
| Outer Clamp Range | 87 – 152mm | 97 – 164mm | 154 – 301mm |
| Repeatability | 0.0008″ | 0.0008″ | 0.0008″ |
| Clamping Force | 900 – 2,500 lbf | 900 – 3,400 lbf | 1,450 – 5,850 lbf |
| Pressure Range | 50 – 130 psi | 50 – 130 psi | 50 – 140 psi |
| Weight | 20 lbs (9 kg) | 24 lbs (11 kg) | 32 lbs (15 kg) |
| Failsafe | 50% force retained | 50% force retained | 50% force retained |
Specialized Rotary AutoVise™ versions are also available for 4th axis workholding and 5th axis workholding applications, featuring a base plate that passes pneumatics directly through the bottom with 1.500″ and 2.000″ centering plates for wide rotary compatibility. For shops running 5 axis vises on trunnion tables, these rotary models offer the same self-centering precision in a compact, through-table pneumatic package.
AutoVise™ vs. Traditional Pneumatic Vise: How Does It Compare?
When evaluating pneumatic workholding for a new automation cell, shops typically weigh the AutoVise™ against retrofitted traditional machine vises or premium European clamping blocks. Here is how this self-centering vise stacks up against a standard pneumatic vise conversion:
| Feature | Gimbel AutoVise™ | Traditional Pneumatic Vise |
| Actuation | Integrated Pneumatic | External Air Cylinder |
| Centering | True Self-Centering | Fixed Back Jaw |
| Construction | All-Steel & Stainless | Cast Iron / Aluminum |
| Repeatability | 0.0008″ (0.02mm) | ~0.001″ – 0.002″ |
| Failsafe | 50% Force on Air Loss | Drops to Zero |
| Op 1 Setup | Adjustable Serrated Hard Jaws | Requires Custom Soft Jaws |
| Buy Online | Yes — Shopify | Dealer / Quote Only |
The ROI of Upgrading to a Self-Centering Pneumatic Vise
The benefits of upgrading to a self-centering pneumatic vise extend far beyond just enabling a robot to load parts. Even for shops that are still manually loading their machines, the AutoVise™ provides an immediate return on investment in CNC workholding efficiency.
Consider the time an operator spends blowing off a traditional cnc mill vise, loading a part, and hand-cranking it tight. It may only take 30 seconds, but multiplied across hundreds of parts a day, that time adds up to hours of lost spindle uptime every week. With a pneumatic CNC vise, clamping is instantaneous and perfectly repeatable. The clamping force is regulated by air pressure, meaning the air vise clamps with the exact same force every single cycle, eliminating the variable of operator fatigue and reducing part deformation.
Furthermore, because the AutoVise™ is a true self centering vise, any variation in the raw stock is split evenly across the centerline. This ensures that toolpaths are always perfectly aligned with the center of the material, drastically reducing setup scrap and ensuring consistent wall thicknesses on finished parts. For shops pursuing lights-out manufacturing or robotic machine tending, this level of repeatability is not optional—it is essential.
The AutoVise™ also integrates seamlessly with CNC machine tending setups using cobots, spindle grippers, or dedicated machine tending robots. Because the vise opens and closes via a simple pneumatic signal triggered by M-code, no additional software or complex integration is required. Shops running cnc mill workholding automation report that the AutoVise™ is typically operational within hours of unboxing.
Stop Hand-Cranking. Start Automating.
Whether integrating a cobot, using spindle grippers, or simply speeding up manual loading—eliminating the hand-crank is the first step toward true machine tending automation.
Learn more at GimbelAutomation.com | Follow @gimbelautomation on Instagram
