    Home»Tormach vs. Syil: Which CNC Manufacturer Should You Choose?
    AdminBy AdminJune 14, 2022Updated:July 19, 20222 Comments7 Mins Read
    CNC machining is an $80 billion industry worldwide. And, as technology evolves, the value of CNC for manufacturing will only increase.
    If you’re interested in creating a product or component with a computer numerical control machine process, chances are you’ll look for machine shop partners with the most reputable brands.
    Two of the best-known brands in the field are Syil CNC and Tomarch. But which CNC manufacturing equipment brand is right for your project?
    In this article, we compare Tormach vs Syil brand CNC equipment. Read on to learn what makes a CNC machining brand high-quality, and how Tomarch and Syil stack up.
    What Makes a CNC Machining Manufacturer High-Quality?
    Before you can establish which qualities to look for in a CNC manufacturer, you must determine the goals of your project. From there, you can work backward to outline your project’s parameters.
    Some qualities demonstrate a manufacturer’s competence, which it can apply to a wide range of projects. Others specifically demonstrate skill or versatility within certain niches, or with specific materials.
    Once you have your project in mind, consider these qualities in a CNC machining facility.
    Project Portfolio Demonstrates Experience
    A CNC manufacturer often has a portfolio of products it has produced for clients. The right manufacturer will have created products with similarities to yours—either in terms of materials, function, or specifications.
    The manufacturer’s portfolio may highlight award-winning designs. Professional and non-profit organizations like the American Society of Mechanical Engineers (ASME) and the Franklin Institute honor achievements in engineering.
    Which manufacturers and machines contributed to winning innovations?
    Look for testimonials by clients whose products are highlighted in portfolios. If possible, contact clients who’ve worked with a manufacturer directly, to get an unbiased opinion.
    Professional Qualifications
    A CNC machining and manufacturing brand should employ qualified professionals. Look for companies whose workers are members of professional organizations. This can include:
    • National Tooling and Machining Association (NTMA)
    • The International Association of Machinists and Aerospace Workers (IAMAW)
    • Society of Manufacturing Engineers (SME)
    Highly-qualified professionals are knowledgeable about machining techniques and applications. They may present tools and strategies at trade shows.
    An innovative R&D team sets a CNC manufacturer apart.
    Workflow
    A high-quality machining manufacturer has an effective workflow. It has strategies in place to update manufacturing processes as needed, without disruption.
    To maintain an efficient workflow, the manufacturer may develop and implement systems. The two most useful systems are:
    • Material Requirements Planning (MRP) system
    • Enterprise Resource Planning (ERP) system
    MRP systems, in particular, make effective inventory management easier. When considering a manufacturing partner, examine how it implements these systems.
    Client Support
    Finally, it’s important to choose a manufacturer that offers excellent client support. It should be easy to get answers to your questions about a project.
    Learn if the manufacturer you want to work with is reachable, and how they tend to communicate.
    How to Evaluate CNC Machines and Equipment
    There are a range of qualities to evaluate in CNC machines and equipment. Let your project set your priorities. Do you need a CNC milling machine or a turning machine?
    Precision, Accuracy, Quality
    The best CNC machines have precise motion systems and tool holders. This precision empowers a degree of intentionality, quality control, and accuracy in your final product design.
    Manufacturers and engineers can test the precision and accuracy of a CNC machine according to International Standards Organization (ISO) processes. Choose CNC machines that come with ISO certification.
    Likewise, the best CNC machines meet the STEP-NC standard. This standard lets machines share measurement information directly.
    As a designer, you may seek machines compatible with simulation and verification software to improve accuracy. This software uses techniques like digital twinning to predict the result of the machine’s process as programmed.
    With these predictions, it’s easier to alter instructions to get the results you want.
    Tool, Function Specifications
    It’s also critical to evaluate a CNC machine’s tools and functions, to make sure it has the capacity to execute your project.
    Determine the minimum required specifications you’ll need in a machine to complete the project on time and under budget. Then, consider the following specifications:
    • Quantity of operations per setting
    • Parts produced per cycle
    • Proportions and geometries of parts produced
    • Range of compatible materials
    • Size of working space
    • Fixture width, length, and height
    • Cutting force
    • Tool capacity
    • Machine spindle power
    • Cycle time of the machine
    Adaptability is a great quality in a machine.
    If a machine is adaptable, you can run additional processes on it. This is particularly useful if you want to build redundancy in a shop (so losing a single machine to repairs doesn’t destroy your capacity).
    Degree of Automation vs Machinist Control
    How much control should a human machinist maintain over the process?
    Fully-automated CNC machines have several benefits. They can manufacture a high volume of parts more quickly, they minimize waste, and their results are highly consistent.
    But, to implement total automation effectively, machinists must be trained to encode instructions properly. You must also install sensors strategically.
    Weigh your ability to manage implementation against the benefits of complete automation.
    Tormach vs. Syil CNC: How Do They Stack Up?
    Tormach and Syil both offer CNC machines at similar price points. And, they both offer similar support services for clients and that is why Tormach vs Syil comparison seems like a wise choice. So, which one is right for you?
    Project Portfolios
    It’s easy to explore Syil’s portfolio online. One client—Le Plus Solutions in Singapore—notes that the Syil CNC machines’ affordability let them scale their semiconductor manufacturing services.
    Another client, stop motion artist Edu Puertas, notes how Syil CNC equipment’s automated features make it easy to use—even for a non-engineer.
    In contrast, Tormach’s consulting portfolio highlights the complete training and licensing it offers clients—along with compatible CAD/CAM software. Tormach’s profiled clients produce complex, bespoke machinery, including firearms.
    CNC Machine and Equipment Capabilities
    All Syil CNC machines meet ISO, CE, and CSA standards.
    Syil focuses on the affordable end of the CNC machine spectrum. Yet, Syil machine specifications are impressive. The Syil X7:
    • Reaches a spindle speed of over 30,000 RPM
    • Rapids at a rate of 30 meters per minute
    • Is powerful enough to work with grade 2 titanium
    Tormach CNC machines comply with ISO and CE standards.
    The Tormach 1100 MX is similarly compact and affordable. But, it doesn’t compete with the Syil X7 in a few key ways. The Tormach 1100 MX:
    • Hits its maximum spindle speed at 10,000 RPM
    • Reaches peak feed rate at 7.62 meters per minute
    • Is powerful enough to work with titanium
    Both Syil and Tormach machines are strong. Production capacity varies from machine to machine. That said, Syil machines offer unique features that can increase their per-cycle capacity, including:
    • Comprehensive cooling system
    • High-speed tool setting
    Due to its compact size, a Syil CNC machine isn’t the right choice for truly mass production.
    But, it’s exactly the right choice for high-speed, precision production. You can turn around relatively high volumes of a product quickly with Syil CNC.
    Client Support
    Syil offers clients both local support and remote support options. All Syil machines come with technical installation and troubleshooting support.
    Syil also offers original equipment manufacturer (OEM) and customization services.
    It’s easy to reach customer support through the support portal online, and by phone.
    Tormach also offers free technical support to clients. Support lasts for the lifetime of the machine.
    Tormach offers additional consulting services to clients with unique manufacturing needs.
    Syil CNC: High-Speed, Affordable Machines
    When you compare Tormach vs Syil, make sure to start with the traits most relevant to your project. Do the machines perform the functions you need? Does each manufacturer implement an efficient workflow and client support?
    Ultimately, both Syil and Tormach make affordable CNC machines. But only Syil machines use thorough cooling systems to maintain a high production volume at speed. And it’s Syil that has mastered the art of compact machinery.
    Interested in what Syil CNC machines can do for you? Get in touch today for a free quote. Our experts can help you find—or build—the machine you need.
    2 Comments
    1. gUVKSLYHGTxbtF on June 20, 2022 5:34 pm
      FCLQUXzZuOB
      Reply
    2. ANDxliKFUgm on June 21, 2022 9:59 pm
      wuKEtOWPbxrcqvY
      Reply
