    Home » Nidec Drive Technology Opens New Press Machine Assembly Factory
    AdminBy AdminApril 16, 2026Updated:July 20, 2026No Comments2 Mins Read
    CHARLOTTE, N.C. (April 14, 2026) – Okuma America Corporation, a world-leading builder of CNC machine tools, controls, automation, and manufacturing systems, is pleased to announce the release of its new Okuma High-pressure Coolant System (OHP), a product designed to provide coolant fluids to Okuma machine tools during machining processes.
    The Okuma High-pressure Coolant System is the newest addition to the company’s growing line of peripheral products to support integrated, seamless manufacturing processes. Designed for demanding machining environments, the OHP Series provides variable flow, high pressure coolant delivery to Okuma machine tools, ensuring optimal chip evacuation, extended tool life, improved surface finishes, and enhanced productivity for modern manufacturing operations. Its robust construction and advanced filtration make it an ideal solution for a wide range of tooling sizes, multi-axis lathes, multi-function machines, and machining centers.
    The OHP Features & Benefits at a Glance
    The Okuma OHP system is compatible with water based coolants and suitable oils, making it versatile for a wide range of shops and applications. Operators benefit from plain English PLC messaging, simplifying system monitoring and maintenance. A dirty filter alarm alerts users when service is required, helping protect tooling and maintain consistent performance.
    The OHP is built to support high precision machining with a powerful 8 GPM flow capacity and 1000 PSI pressure capability. Its dual 7×32”, 5 micron quick change filter bags ensure exceptional coolant cleanliness, while the 50 gallon vertical reservoir and built in feed/supply pump support long, uninterrupted machining cycles.
    Standard Features Include:
    • 8 GPM flow rate
    • 1000 PSI pressure capability
    • (2) 7×32″ 5-micron quick-change filter bags
    • 50-gallon vertical reservoir
    • Built-in feed/supply pump
    • 208/230V standard; 480V available
    • Compatible with water-based coolants or suitable oils
    • Clear English-language PLC notifications
    • Dirty filter alarm
    • 2-year parts warranty
    • Compact, Shop-Friendly Footprint: 36″ L x 28″ W x 42″ H
      • Weight: 850 lbs.
    “We at Okuma are dedicated to helping our customers succeed and reach greater potential for their businesses”, said Wade Anderson, Vice President of Engineering and Okuma Factory Automation. “The launch of this new high pressure coolant system is an example of how Okuma is working to create an easy to implement manufacturing systems to support efficiencies and growth.”
    For more information about Okuma America Corporation and the OHP series, visit www.okuma.com/products/high-pressure-coolant.
