    Home » Swarfblog » Swarfcast Ep. 10 – John Griner, Twists and Turns of a Hydromat Shop
    Noah GraffBy Noah GraffSeptember 13, 2018Updated:September 21, 20181 Comment1 Min Read
    Scroll down to listen to the podcast with John Griner.
    In today’s Podcast we interviewed John Griner, founder of Griner Engineering in Bloomington, Indiana.
    John has been cranking out turned parts for the last 40 years, and since the ‘90s his bread and butter has been the legacy Hydromat business.
    He’s a renaissance man. He studies philosophy, flies planes and has played the guitar for 50 years. He has had 34 different startup businesses as diverse as centerless bar stock grinding, cold forming, video production, and an exotic animal business called “wild things.” But in the end, the one that always stuck was the multi-spindle/Hydromat business.
    John Griner in New Orleans
    We talked to John about how his machining business has evolved over the years. He started running single spindle screw machines, graduated to cam multi-spindles, then added Hydromats and finally introduced modern CNC turning equipment into the mix.
    John talked with us about how he copes when deals go bad, how he finds good employees and why he prefers not to drug test in his shop.
    Question: Is a strict drug testing policy a necessity for a successful machine shop?
    September 8, 2026
    Why the Cubs
    September 4, 2026
    August 25, 2026
    August 19, 2026
    1. Klee Dangler on September 17, 2018 10:28 am
      We currently do not test but, have thought about doing so I guess I need more reasons to or not to do so?? I believe our team does not use but, how do you know for sure?? If you do test & Everyone passes, what effect does that leave with them! Please, “give me your thoughts on this”? Undecided??? Thanks!! Klee Dangler- Tooling Connection LLC
